Knowledge Quiz for Warbird wiz
Morning clue. Thanks; Ernie P.
What warbird do I describe?
1. This was a significant aircraft.
2. Not only for the owning nation, but within the world aviation community.
3. Between 50 and 100 were built.
4. It was armed with three guns.
Afternoon clue. Thanks; Ernie P.
5. Two prototypes were produced and tested.
A bit late, but here's your evening clue. Thanks; Ernie P.
6. Then 21 more were produced for “evaluation”.
7. It was a conventional plane in many regards.
8. It was a monoplane with strut reinforcement.
Evening clue. Thanks; Ernie P.
9. With fixed landing gear.
10. The plane was reported as flying well.
11. Its speed was okay for the time.
12. Overall performance wasn’t outstanding, but neither was it poor.
Today's clue. Thanks; Ernie P.
13. Even so, by the time the evaluation models were all delivered, it was obvious things weren’t going well.
14. The problem was in the amount of ammunition carried.
15. Which was inadequate.
Guys; the day got busy but here's the afternoon and evening clues. Thanks; Ernie P.
16. One of the guns was used for sighting.
17. Sighting for the other two guns.
6. Then 21 more were produced for evaluation.
12. Overall performance wasnt outstanding, but neither was it poor.
13. Even so, by the time the evaluation models were all delivered, it was obvious things werent going well.
18. Which carried quite a punch.
Morning and afternoon clues. Thanks; Ernie P.
19. For a very short time.
20. And that was what ended this planes use.
HJ; I'm starting to think you're the only one following this question. But keep it up! No, not the Bf-108; but here's a bonus clue to help your search. Thanks; Ernie P.
21. Afterwards, the planes already produced were simply used for testing in various projects.
20. And that was what ended this plane’s use.
22. One of which was use as a parasite fighter.
23. Various parts of the plane had to be reinforced to deal with the blast effects of the armament.
All;
Figuring early is better than late, here's the afternoon clue. Thanks; Ernie P.
24. Particularly the rear fuselage and tail surfaces.
Ooooh.... I'm doing well. Actually, HJ; that should make you think "Blast effects? What kind of armament makes a blast effect large enough that things have to be reinforced"? And I'll toss in a bonus clue to help you get reoriented. Thanks; Ernie P.
25. The sighting machine gun was mounted on the left fuselage.
