Reload this Page >
CARF-Models Mig 17 build thread
Old 09-18-2022, 10:16 AM
  #176
Dave Wilshere
Two Migs flown today at the U.K. home of model jets Abingdon. Now identical in set up with RB owner swapping to Core before the test flight, I set the model up exactly as mine and both flew without a single peep of trim. The JetCat P-220 Rxi set ups give 9+ minutes and perfect scale power. Landing roll in the 12mph wind we had today was 45’ or less!
Anyone without assistance the model needs little to no expo and as much movement you can get.
Our gear is both running small low C 2s Li-Po batteries and we need to slow up and stol climbing to reliably get the gear away. I’ll try a 3s Li-Fe next time.
Awesome models though.
The following 4 users liked this post by Dave Wilshere:
Canadian Man (09-26-2022), David J Ruskin (09-19-2022), jcterrettaz (09-24-2022), Skunkwrks (10-17-2022)
Old 09-18-2022, 09:31 PM
  #177
LA jetguy
LA jetguy's Avatar
Congrats Dave…. Danny has just started on mine.. can you share the CG and surface deflection you used for both MiG’s
David
Old 09-18-2022, 11:35 PM
  #178
Dave Wilshere
David
I will put together some notes, but the easy thing is you want as much control movement you can get. These are both at the natural mechanical maximum for Aileron and elevator and are very smooth and soft. It’s an incredibly smooth flying aeroplane. Anyone who has flown the larger models (1/4 scale plus) will know they are never twitchy.
Balance was done on both of these with fuel in the main tank 1” below the fuel line fitting (almost half a tank) as again the fuel in just in front of the balance point and I wanted an average. It’s 28cm from the wing trailing edge with this fuel. I trapped a cord in the joint and lifted, no electronic variable figures! The RB Mig was originally balanced a different way and the builder had glued weight into the tail cone! Luckily I queried it and he redid it with string and ended up having to add lots of nose weight!
The aeroplane flies so light it could be 30kg wet and still would not care!
CARF build a super straight aeroplane, neither needed one peep of trim on any surface!
Dave
The following 2 users liked this post by Dave Wilshere:
David J Ruskin (09-19-2022), Skunkwrks (10-17-2022)
Old 09-19-2022, 03:23 AM
  #179
F1 Rocket
Hi Dave,
Just getting started on David’s MiG. Does it tend to build nose or tail heavy.
Danny
Old 09-19-2022, 04:08 AM
  #180
Dave Wilshere
Danny
Presuming you are building as with all the detail I think it comes down to wire you use on the Afterburner set up, heavier wire pulls it back a little. It can definitely be built without weight, you can see my set up, if I had used the 5000 PB Rx packs I could remove the small amount of weight I have in the nose. It’s an aeroplane with a small tail, so it can fly like it’s nose heavy, but it’s just the lack of ‘stabiliser’ balanced front of the rear wing tube is 27cm and I would not go further back than that, when you stall it it needs flying out at this position. 28cm with half a main tank is the sweet spot.
Dave
Old 09-19-2022, 04:12 AM
  #181
Dave Wilshere
This was my final solution to my ‘short’ van. The plate on the bulkhead has 4x carbon pegs and the bracket folds down when the Mig isn’t been transported. The Velcro strap is just for support when I remove the bracket to take the fuse out.
Old 09-19-2022, 08:45 AM
  #182
jackdiazccs
My solution
Old 09-19-2022, 09:56 AM
  #183
Dave Wilshere
With my solution the fragile surface won’t get damaged and I can get another couple of jets in too!
Old 09-19-2022, 10:16 AM
  #184
jackdiazccs
Originally Posted by dave wilshere
with my solution the fragile surface won’t get damaged and i can get another couple of jets in too!
lol !!!
Old 09-19-2022, 10:33 AM
  #185
causeitflies
causeitflies's Avatar
Plenty of room for a couple more jets
Ron S (09-26-2022)
Old 09-19-2022, 11:08 AM
  #186
Dave Wilshere
I generally pack my van like that…just not with the Mig
Old 09-19-2022, 08:59 PM
  #187
LA jetguy
LA jetguy's Avatar
Thanks Dave
Old 09-24-2022, 11:20 AM
  #188
JP-1
D.W. was flying his CARF Mig 17 at the U.K. JMA meeting at Buckminster Lodge, it looks superb, both on the ground and in the air
Alistair Powers
The following 2 users liked this post by JP-1:
jcterrettaz (09-24-2022), Viper1GJ (09-24-2022)
Old 09-24-2022, 03:07 PM
  #189
jcterrettaz
jcterrettaz's Avatar
such a sexy jet , great pictures BTW
Old 09-26-2022, 12:03 PM
  #190
Auburn02
Auburn02's Avatar
Originally Posted by Newton5019
Dave
How much clearance is there between bootom of turbine and tank directly underneath ?
T
FWIW, confirmed live and in person this weekend that the one I referenced is flying with a Dragon (133mm diameter per spec), and has the stock center tank. It's tight, but it's there.
Old 09-27-2022, 11:47 AM
  #191
Dave Wilshere
More pictures from AP.
Old 09-27-2022, 12:04 PM
  #192
JP-1
D.W.s Mig 17 at Buckminster JMA meeting
Alistair Powers
Bob_B (09-28-2022)
Old 10-03-2022, 01:06 PM
  #193
Dave Wilshere
More great pictures from AP over on the Elvington thread.
Old 10-15-2022, 05:56 AM
  #194
Canadian Man
Canadian Man's Avatar
What a beauty!!!!!
Dave, Hope you don't mind me adding these to your thread.
The following 3 users liked this post by Canadian Man:
CostasV (11-18-2022), LA jetguy (10-15-2022), Skunkwrks (10-17-2022)
Old 10-15-2022, 09:06 AM
  #195
Dave Wilshere
Not my thread…it’s RCU’s and more the better!
The following 3 users liked this post by Dave Wilshere:
Balou88 (12-12-2022), Canadian Man (10-16-2022), Skunkwrks (11-09-2022)
Old 11-02-2022, 08:14 AM
  #196
Canadian Man
Tail section complete in the first video. Engine mounted and Airbrakes started.
The following 2 users liked this post by Canadian Man:
CostasV (11-18-2022), paulhat (11-03-2022)
Old 11-09-2022, 07:35 AM
  #197
Canadian Man
She is going together very quickly!
Old 11-16-2022, 07:05 AM
  #198
Canadian Man
Almost done! Now the cockpit to come.
CostasV (11-18-2022), skymaster68 (11-17-2022), yeahbaby (11-17-2022)
Old 12-10-2022, 07:31 AM
  #199
Canadian Man
The Cockpit how to Video.
What a challenge this thing is but rewarding when it's done.
Old 12-10-2022, 10:06 AM
  #200
Dave Wilshere
Been flying mine again today…
paulhat (12-10-2022)
