Reload this Page >
Pilot-rc PREDATOR 2.2m Sport jet / full composite
Old 12-18-2018, 06:44 AM
  #351
Agrav8ed
Originally Posted by why_fly_high
Kingtech 210. Yes. The tank is ahead of the CG so probably safe to have a little fuel in the tank being that you would hope to never land completely dry. I didn't weigh the TV items but would guess with the servo and linkages 6-8oz way back in the tail. As I mentioned, not unexpected. I just wanted to throw this out there for anyone else running the TV so they don't look at the install pictures and just copy those and then get a surprise. I am not going to have to add any ballast so not a big deal.
Could you take some picks of your setup placement and the thrust vectoring? Decent pics of the thrust vectoring set up are fairly hard to find.
thanks,
Tone
Old 12-18-2018, 07:35 AM
  #352
why_fly_high
My Feedback: (19)
I can see about pictures of the TV. you will only be able to see the back end. The servos and such aren't visible. My stuff isn't really mounted yet, just set in for the CG check. I will take pictures once everything is in place and mounted.
Old 12-22-2018, 11:34 PM
  #353
jimboq8
Default Wing tube
Apart from the paint chipping off around the ailerons and flaps I’ve hd no real issue with the plane till yesterday when I noticed the wing kept creeping out after each flight, bolt tight and reset after each flight then I noticed the wing tube had a bend in it. Has anyone had the same issue?
I’ve had about 8 flights on it. All landings were greasers and I’ve put no real force on the plane ( certainly less than my mates and his is still straight).
Old 12-23-2018, 06:11 AM
  #354
horsefeetky
wow i wonder if it had any bend in it from shipping and just now noticed ... we put wing tubes that size through heck in many other planes and even 3d stuf with hard pulls but i cant ever remember bending a tube in flight. your gear should rip out or other signs of hard landing with such a force.. fingers crossed mine holds up well.............may check the diameter and see if i can sleeve the inside with a carbon tube.
Old 12-23-2018, 07:24 AM
  #355
jimboq8
I didn’t notice. I’m on way to get another one and planning on sleeving it cheers.
Old 12-30-2018, 05:16 PM
  #356
oukenfold
Default predator down!!
well the turbine did not respond and start making fire explosion but did not flame out whats happend i dont know?
Old 12-30-2018, 05:41 PM
  #357
jimboq8
Since sleeving the new wing tube I felt a lot happier flying the plane. And when it landed after the first few flights also noticed that the wing hadn’t come apart during flight. I think the reason it was separating was the tube was flexing during flight and forcing the wing to separate.
Anyway all sorted now. Will look for something else to sleeve the elevators and I’ll be way more happier.
Old 12-30-2018, 09:59 PM
  #358
why_fly_high
My Feedback: (19)
Default Mine is getting close
Here is a link to a quick video of the tv in the shop
Old 01-01-2019, 04:52 PM
  #359
blainer48
My Feedback: (30)
I'm thinking about ordering one of these and putting my K-160G2 in it. Has anyone had any issues with the Pilot servos? I'm debating on the turbine ready version or the landing gear, tailpipe version and using my own servos. Just curious how the Pilot servos are holding up. Thanks.
Jason
Old 01-01-2019, 06:24 PM
  #360
DHC6
DHC6's Avatar
I put about 100 flights on my turbine ready version and the servos are working great. I found the flaps could use a little more power, but they work just fine. I am very satisfied with the Pilot servos.
Old 01-02-2019, 05:00 AM
  #361
horsefeetky
not yet flown mine but the setup with those servos went fine and they are very fast my gyro will like them. i am please with the plane in turbine ready form so far. now just waiting on kingtech servoce to start back up for 2019 and look over my 180g that was pouring fuel and not starting..............go figure always something
Old 01-03-2019, 05:21 AM
  #362
Pilot-RC
https://youtu.be/lF5qS6ovXr8
vector thrust move too much end point. it touch the bolt. I can hear the sound it hit the bolt. pls double check it.
Old 01-03-2019, 08:23 AM
  #363
why_fly_high
My Feedback: (19)
Thanks Tony. This was an initial test. I had set the end points individually but when maxed in 2 directions I think it was binding a little. I will be checking everything a few more times before it is flown.
Dan
Old 01-04-2019, 05:38 PM
  #364
blainer48
My Feedback: (30)
Are you guys using the stock tank with the built in UAT? Also does anyone have a picture of how it's actually plumbed. I look at the manual online but not the best pictures. I'm actually thinking of getting the version that isn't turbine ready and use my own servos. No where has the turbine ready version available. Closest is chief aircraft and that's not until April-May.
Jason
Old 01-05-2019, 05:05 AM
  #365
dccatl
I’m using the stock tank and UAT
I got the version without servos and used Pro Modeler DS470BLHV servo which have performed perfectly.
Old 01-05-2019, 07:16 PM
  #366
Pilot-RC
Default 2019 new predator scheme: No.17 scheme
more new scheme is coming! ready for order. please contact with your local dealer:
Pilot-RC World Dealers - Pilot-RC
more detail photos;
No.17 scheme photos
Old 01-06-2019, 05:37 AM
  #367
horsefeetky
i like the canopy paint and the 2 part fuse..rudder has a bit different tilt i think also
seems things are always getting better
Old 01-06-2019, 05:52 PM
  #368
Sparhawk
Sparhawk's Avatar
�� Good looking scheme Tony!
Old 01-16-2019, 05:28 PM
  #369
blainer48
My Feedback: (30)
I have a question that I hope someone can please answer. So, I just got my Predator and unboxed it. First thing I noticed was that it is a 2 piece fuse and the tail pipe isn't mounted. So, my question is how in the hell am I suppose to drill and screw anything to secure the pipe and second I have no idea how I am going to put the bottom 3 screws in to bolt the fuse together. I don't see how I can bolt the fuse then put the pipe in because of the former unless I'm looking at it wrong. Mind you I just unboxed it so I haven't sat and looked at it long. Just curious what you guys did to mount the pipe.
Jason
Old 01-16-2019, 05:52 PM
  #370
Pilot-RC
Jason
push the tail pipe to the back of the fuselage. rear of the tail pipe should be pushed out of the rear of the fuselage. then you can do it.
the tail pipe fix after you connect the two piece of fuselage.
thanks.
Old 01-17-2019, 03:20 AM
  #371
swk550
My Feedback: (76)
swk550's Avatar
Has anyone used a Spektrum A7040 retract servo for flaps? The servo is proportional and accepts end point adjustments. Torque rating looks abought right.
Old 01-18-2019, 05:06 PM
  #372
swk550
My Feedback: (76)
swk550's Avatar
Default A7040 servo not suitable
I made a mount for this wider Spektrum A7040 servo. Had to cut down travel to suite. No good. Too much gear slop and poor centering. I’ll need to install a quality 20kg-cm servo on the flaps. What servos are good for flaps? I am using Futaba bls175sv servos for the control surfaces (A, E, R). The Futaba servos are great, but maybe an over kill for flaps.
Old 01-18-2019, 08:28 PM
  #373
shepga
Too much gear slop and poor centering with the Futaba bls175???
Old 01-18-2019, 10:50 PM
  #374
swk550
My Feedback: (76)
swk550's Avatar
Sorry, poorly written first response. Futaba servos are great for aileron, elevator and rudder, no problems. It’s the Spektrum A7040 retract servo that’s no good for flaps.
Old 01-20-2019, 03:00 PM
  #375
blainer48
My Feedback: (30)
Do any of you have pictures or what did you do to mount a smaller turbine like a K-160. I noticed it doesn't sit on the factory rails so there are these little tabs for mounting "smaller turbines". I don't really like the factory ones because they look way to thin for my liking. Just curious what some others have done. Thanks.
Jason
