Reload this Page >
Pilot-rc PREDATOR 2.2m Sport jet / full composite
Old 12-01-2022, 10:15 AM
  #701
bobzilla
My Feedback: (63)
bobzilla's Avatar
Default predator
Wings attach with bolts from LE and TE by flaps into blind nuts in fuselage. On TE, fill in the area on flap so bolt does not get trapped in end of flap.
Old 12-01-2022, 12:52 PM
  #702
bodywerks
bodywerks's Avatar
Originally Posted by BarracudaHockey
I'm a little surprised you feel like you can break a Rebel and yet the Predator will hold up.
I've seen some pretty extreme flying with Rebels, way harder than I can push mine without any failures.
High speed passes with a 170, snap-rolls, etc.Hatch started cracking at the intake and pressure buffeting of the fuse would cause the hatch retention pin to start working its way out in flight. I'd have another if they could laminate some carbon reinforcement in key areas. It only weighed 22lbs dry. The Predator is heavier but at least it has some carbon in it, and other structural laminations built into it, whereas the Rebel fuse is just a basic fiberglass lay-up with some formers in it.
Old 12-01-2022, 05:42 PM
  #703
bodywerks
bodywerks's Avatar
One more question and then I'll get to assembly: Did they ever fix the stab incidence issue that basically required about 1/8" up elevator trim?
Old 12-01-2022, 06:34 PM
  #704
bodywerks
bodywerks's Avatar
Default First round of disappointment
Fuselage is now 1 piece
you set me up for disappointment. No way this is one piece. Now I wonder if I also missed out on the wing attachment update, bigger wing tube, better tank, and lighter weight. Won't know till tomorrow.
Did you order direct from pilot-RC? What was price to your door if you don't mind me asking? Ima be a little upset if I paid full price for old, outdated stock. This was $3700tmd. ARF would have been $2800.
Old 12-01-2022, 06:56 PM
  #705
bobzilla
My Feedback: (63)
bobzilla's Avatar
Default predator
Never had an issue with trim up elevator on 5 predators, wonder who started that.
The box for 1 piece fuselage is super long.
Old 12-01-2022, 08:08 PM
  #706
bodywerks
bodywerks's Avatar
re-read this thread. almost every predator jet carries at least 1/16" up elevator, most 1/8". My old predator carried 3/32".
Honestly, two piece fuse least of my worries, but all the other changes you mentioned are exactly from the failures I experienced. My last predator:
- bent the wing tube
- had a dead stick due to tank malfunction
-wings would separate from fuse in flight due to flawed retention design.
if I paid same price as you for an inferior design, I have a problem.
Old 12-01-2022, 08:29 PM
  #707
bobzilla
My Feedback: (63)
bobzilla's Avatar
Default predator
I can only assume all 5 of my predator which had the exact cg to each other, never had an elevator up problem, must have been correct for me.
Old 12-01-2022, 09:02 PM
  #708
bodywerks
bodywerks's Avatar
Well, got it opened and other than two piece fuse, appears to have all the other updates, except not sure about wing tube.
what diameter and thickness is yours? This is 25mmx 2mm. I think that's the same as my last one that bent.
Old 12-10-2022, 12:38 PM
  #709
bodywerks
bodywerks's Avatar
Just got the turbine installed. I didn't take a pic but I noticed the swiwin turbine exhaust sits high in relation to the jet pipe, by probably 1/8"or so. I verified that it's not the pipe itself as it is same incidence as the wing. Has anyone else noticed this?
Old 12-12-2022, 03:28 PM
  #710
bodywerks
bodywerks's Avatar
here's a pic. Not too concerned, just wondering if anyone else experienced this?
What is concerning, is one of my flap servos died on me while setting them up. Servo mount plate was quite warm. Turns out the flap hinge is poorly established, for lack of a better term. I'll deal with that separately, but does anyone know if the servos have some sort of thermal shutdown protection, or is the servo likely toast?
Old 12-12-2022, 04:00 PM
  #711
Dansy
My Feedback: (53)
Dansy's Avatar
Engine need to be Center in the pipe…..do whatever is required to do that…..meaning raise the pipe or the motor….ect…
What servo are you talking about?
Old 12-12-2022, 04:47 PM
  #712
Skunkwrks
Skunkwrks's Avatar
I had three servos that died in the flaps position, one with no servo arm attached, the second was sitting idle, then poof, three one died just prior to maiden.
Same manufacturer on all three and they have refused to do anything after t was brought up to them .
Old 12-13-2022, 01:59 PM
  #713
bodywerks
bodywerks's Avatar
Raising the front of the jetpipe would change the thrust angle. incidence in 0:0 in relation to the wing. I already chiseled away at the mount plate 1/16" to get it closer.
The servos are the Pilot digital 27g hv servos that come with the turbine ready version. I was informed by Tony at Pilot that the servos do have built-in thermal protection. But now I have to figure out how to fix the flap hinge.
Old 12-13-2022, 02:04 PM
  #714
bodywerks
bodywerks's Avatar
These are Pilot factory pre-installed servos from the turbine-ready version. This is my second Pilot 2.2 predator. First one never had a servo problem in several hundred flights. This servo worked again after it cooled down. it was the improperly established flap hinge that over-worked the servo.
Old 12-13-2022, 03:04 PM
  #715
Dansy
My Feedback: (53)
Dansy's Avatar
Changing the thrust angle….really Ahah….that’s not a prop plane, I have done that many time…..I also lower and raise the engine…..much better the chiseled the engine rail…
Old 12-14-2022, 08:59 AM
  #716
bodywerks
bodywerks's Avatar
Raise the engine=easy. Lowering=not so much. I'm not about to cut out the rails of a 'turbine ready' ARF and glue in new ones. Surely I am not the only person here that has a laser cut, jig-locked turbine rail assembly that was incorrectly centered. I also disagree that changing the incidence of the thrust tube doesn't change the thrust angle of the turbine exhaust. It's literally how thrust vectoring works.
Old 12-16-2022, 08:57 AM
  #717
dvcam99
Hello together,
just made a quick foto of my EVO Jet turbine line up inside the Predator.
May this helps you a bit.
I`ll checked my elevator neutral flight trim too and it shows aprox. 1mm up trim.
BR
Dirk
Old 12-22-2022, 07:13 PM
  #718
airborn900
My Feedback: (25)
Just ordered a predator 2.2. I know it will be a 2 piece fuse. What should I be looking for to make sure it has the correct updates to be safe. Wing attachment at LE and Flap bay, what is the correct wing tube size? Is there a carbon tube recommendation or replacement? Any pro/con in changing the tube out?
got the red and yellow one
wife says it looks like a Pheonix.
Old 02-22-2023, 10:22 AM
  #719
bodywerks
bodywerks's Avatar
If you ordered it from banana hobby it is updated for sure, but yes, it will have bolts retaining wings n stabs, wing tube will be like 2.5mm thick, and UAT will no longer be integrated into the main tank.
Old 03-15-2023, 09:20 AM
  #720
rmb
Default Rmb
My Predator just arrived servo brackets are plastic shown as aluminium in manual would you advise using them?
Old 03-15-2023, 09:30 AM
  #721
bobzilla
My Feedback: (63)
bobzilla's Avatar
Default brackets
Show pictures
Old 03-15-2023, 10:47 AM
  #722
rmb
Sorry can't upload photos until I have submitted 10 posts not there yet. These brackets are the right angle brackets that you screw rudder aileron and flap servos to. 10 comes with kit.
Old 03-15-2023, 12:03 PM
  #723
rmb
Old 03-15-2023, 01:06 PM
  #724
bobzilla
My Feedback: (63)
bobzilla's Avatar
Default brackets
Yes, those are great. Used them on 5 predators, zero problems
Old 03-15-2023, 04:35 PM
  #725
rmb
Thanks just looking for reassurance. Could anyone give me some idea if this would be a later version of the Predator, wings clamp LE and TE, screw locks canopy on and fuel tank and air trap are separate.
