Everything Diesel Discuss R/C Diesel engines here.
need iformation on old diesels
Old 07-25-2023, 10:14 AM
  #201
beatsal
Thanks. Here are 2 pics.
File Type: zip
File Type: zip
Old 07-25-2023, 06:49 PM
  #202
1QwkSport2.5r
1QwkSport2.5r's Avatar
I would suggest not posting zip files. Zip files do not work well with mobile devices which many people use these days. Try posting .JPG or .PNG images instead.
Old 07-26-2023, 03:13 AM
  #203
Coxfledgling
Default Merlin
Yep, refuses to open but thumbnail picture seen. That also refuses to open it be zoom inable.
You have access to a small lathe or are good at metal working at all ?
Old 07-26-2023, 04:15 AM
  #204
beatsal
Another pic
Old 07-26-2023, 04:23 AM
  #205
beatsal
Another pic!
Old 07-26-2023, 04:26 AM
  #206
beatsal
Not very good at metal work but think I can manage
Old 07-26-2023, 04:54 PM
  #207
Ployd
I would strongly recommend you remove the needle valve assembly and re-assemble with the fuel needle on the right hand side of the engine facing away from the prop (original factory installation). The way you have it installed is an accident waiting to happen.
Ployd in OZ
beatsal (07-27-2023)
Old 07-26-2023, 11:33 PM
  #208
Coxfledgling
Default Merlin
Absolutely as above...whilst it out, make a bracket to form a mounting point for a "slide flap" that will cover the Venturi hole to restrict the hole size via an RC servo which will allow "some" control of engine speed.
Alternatively make a Venturi extension that fits the Venturi tube outside with a similar ( cylindrical ) rotating means of controlling air intake diameter to control engine speed.
Also, a good fit tube with exhaust ports that fits over the engines exhaust ports and can rotate to control effective exhaust port size, thus giving some control of engine speed.
Note, the compression lever in your picture is set to full compression as it is right up against the stop pin.
How far have you stripped this engine down and does it run ?
What model where you thinking of putting this engine in ?
Old 07-27-2023, 04:15 AM
  #209
beatsal
I haven't stripped this engine. I had tried it 2 months ago and it fired but I did not run it - now having trouble starting it - maybe compression is too high? Thinking of trying it on the GWS Slowstick.
Old 07-28-2023, 07:19 AM
  #210
beatsal
Here is a pic of the fuel tank but not sure how it fits on the engine
DC Merlin fuel tank
Old 07-28-2023, 10:10 AM
  #211
Coxfledgling
Default Merlin
Is there a central hole on the tank ?
Anything on the engine have a central threaded hole by chance ?
Old 07-28-2023, 10:45 AM
  #212
beatsal
Yes, there is a central 4 BA threaded hole in the tank, no central hole on the engine.
Old 07-28-2023, 05:11 PM
  #213
Ployd
It's not a Merlin tank as the original was a separate plastic unit that bolted to the backplate using the existing two screws.
Put that tank back in the "spares" box and learn how to make a small metal tank out of K&S tin plate. My friend, you have a lot to learn.
Ployd in OZ
The following 2 users liked this post by Ployd:
1QwkSport2.5r (07-29-2023), beatsal (07-28-2023)
Old 08-01-2023, 07:44 AM
  #214
beatsal
"However an RC fuel "kill" system could be made to stop engine when things go wrong."
Thanks. Looking for ideas how to implement this.
Old 08-02-2023, 10:02 AM
  #215
Coxfledgling
Default Merlin
Hi beatsal,
I remember the clear plastic "squareish" fuel tanks well. I will try to postage a picture so you know what they look like.
Please post a picture of the end plate/rear c/case cover....
If I remember right the end plate has a central "spigot" that may be drilled and threaded to take a 4ba screw that you mention, to secure your tubular tank.
Does your tubular tank have a flat end plate, with the front end of the tank sitting in the recessed engine end plate ?
Soft fuel tolerant black rubber fuel hose can be "squashed" to cut fuel flow via a servo arm arrangement.
You could fabricate a servo controlled Venturi flap to control engine speed to some extent, and/or a servo controlled exhaust "ring" to restrict exhaust gas flow thus controlling engine speed somewhat.
In the past I have flown 2 channel RC planes with an uncontrolled engine, BUT, once you launch a plane of this type, you have NO ENGINE CONTROL whatsoever !!!!!!!!
These days I consider this to be very negligent !
You seem to be a tyro........
Powered free flight planes need a LOT OF SKILL to trim and fly and need LOTS OF SPACE to fly in !!!!!!!!!!!!!!?
Are you based in Canada ?
Go to a club and have a look-see.....slope soaring is wonderful, RC gliders are good.
Your Merlin would power a smallish glider, 2 channel with a smallish tank giving say a 2 minutes engine run to gain hieght, then hunt for a thermal or just glide around for a little while and land. You will need a suitable flying site, the skills to fly it, any legal requirements satisfied and INSURANCE !!!!!!!!!!!!!!!!!!!!!!!!!
Old 08-02-2023, 10:37 AM
  #216
beatsal
Here are 2 pics of Merlin, if not clear, let me know and I can take more pics
Old 08-02-2023, 10:39 AM
  #217
beatsal
I have changed the position of the needle valve to the other side as per comment rec'd
Old 08-02-2023, 10:49 PM
  #218
Ployd
This is a Merlin tank, 10cc capacity and bolts direct to the back plate via the 2 bolts. I believe the later ones were moulded from nylon and you may find on "evilbay"
This talk of fitting "flaps" to the venturi is a waste of effort and I would go far as saying that such a conversion would be beyong the abilities of Beatsal to execute and quite frankly unnessessary. If you wish to shut the engine down quickly then a servo activated cut-out that squeezes the fuel line would be a better way to go and simple to make.
Your choice of model Beatsal is not a Tomboy by a long shot (yes I have checked) and would have you crashing it faster than you can fly it. If a Tomboy style model is what you are after then go to Outerzone website and type in "Vic Smeed Tomboy" and you will see it is a simple model and practical for 3 channel radio. There are kits available from the UK and Australia.
If you go to Google type in " r/c Tomboy model" you will probably find videos and tutorials available. Leave the "GWS Slowstick" where it belongs....on the dealers shelf.
Ployd in OZ
beatsal (08-04-2023)
Old 08-04-2023, 08:16 AM
  #219
beatsal
Still trying to start my DC merlin - very stubborn, shows sign of starting but sadly does not!
I have this glow plug - wonder if anyone would know or guess the make or model
glow-plug engine
Old 08-05-2023, 12:09 PM
  #220
Coxfledgling
Default Cox
Cox 049 baby bee...is there any gold anodising on the central Allo tank at all ?
Visit Cox model engine forum...does it turn over at all...?
Parts available from Cox international, exmodelengines, mecoa, and in the UK, Deb's model supplies...
Don't try and start it untill you have done your research, proper research.
Cox must have made millions and millions of these little gems, and others.
Did you get a plastic plane with it ?
They can be silenced and rc'd these days.
Your Merlin, are you using proper model diesel fuel like model Technics d1000 and have you backed off the compression lever ?
By the way it looks as if the prop is on backwards but that's the least of your worries.....
Old 08-05-2023, 12:12 PM
  #221
Coxfledgling
Default Cox
Could be a Cox peewee 020, measure piston diameter and visit cef, Cox engine forum.
Old 08-05-2023, 12:15 PM
  #222
Coxfledgling
Default Cox
Thimble drone...
Dens model supplies
Old 08-05-2023, 01:16 PM
  #223
beatsal
Yes, it turns. Here is a closeup of the tank, looks like anodised. Any suggestions for a prop to buy? No did not get plastic plane with it.
CLOSEUP OF TANK
Old 08-05-2023, 11:19 PM
  #224
Coxfledgling
Default Cox
Visit cef, Cox engine forum for encyclopedic knowledge data base...
Do your proper research...
The tank is between the engine and end plate with the mesh filter and needle valve...
Do your research
beatsal (08-06-2023)
Old 08-12-2023, 10:59 AM
  #225
Coxfledgling
Default Bb
Did you visit the Cox engine forum yey by chance ?
