need iformation on old diesels
#127
CA
As for flicking, don't use your entire hand and your arm. Try using two fingers (index + middle) and practice flicking from your wrist in a snappy fashion. Watching some YouTube videos of people starting Diesels may also be helpful.
#128
At long last today it started. Without all of your advice, I would still be flicking it for a few more weeks! Thanks.
I now want to build an airplane to use this engine - suggestions appreciated.
#134
Castor gum
Hurrah, she runs !!!
Now get used to starting her a tuning for good running. Not to weak and not too much compression.
Remember lessons learnt about fuel tank etc..
It's not an Rc engine ( but could be ) and has no silencer.
It's not really advisable to have a non RC engine in an RC plane, unless it's a glider and short engine run to gain hieght.
However an RC fuel "kill" system could be made to stop engine when things go wrong.
I would think about a period model.
You know of outer zone or do you want a kit ?
Any RC experience, or control line experience ?
So glad she is a runner.
beatsal (01-04-2023)
#137
Castor gum
Period model, a model of the same era as the engine.
No RC or control line experience....
Free flight ? Forget that, your life is tooo short.
See outer zone...
I would recommend an RC convertion of the centinal "found" model. It's rubber powered free flight but converts easily to RC. Your engine is way too powerfully for its original size but scaled up X3 and engine RC converted, would be a good beginners model I feel.
Perhaps a super 60 for your engine, but again an RC convertion needed for your engine.
Find a club near you. Watch control line flying and RC flying, see if it takes your fancy.
DO NOT go it alone, you will need some training for RC ( a lot ) and cl flying.
Good luck.
So glad your engine runs, make a display shelf for it to extend its life.
Over and out from me.
See outer zone...
Good luck.
#138
"I would recommend an RC convertion of the centinal "found" model. It's rubber powered free flight but converts easily to RC. Your engine is way too powerfully for its original size but scaled up X3 and engine RC converted, would be a good beginners model I feel."
This looks a good idea. So, you are saying a sentinel model converted to RC upscaled X3 and powered by my engine? No luck so far in converting mine to RC, may be use it as CL?
#139
A pic of my DUBRO fuel tan - does not work in this config. fuel doesn't flow. So far, used my homemade tank but now have to put engine in an airplane it hence need dubro.
dubro vent tube on top fuel line at bottom
#141
CA
In any event, the standard cap which comes with the nylon tanks is usually good for glow fuel only. If you don't have it already, you'd need to order a cap kit for diesel fuel.
--Ates
#143
It's the internal tank connections that are important. From your pic it seems like you have none. you need a piece of internal tubing connected to one of the Brass internal pipes to a length of tubing with a brass barb on the end. The DuBro tank needs extensive modification for diesel fuel which makes it inpractible in my opinion. All the tubing needs to be Tygon and the plug the alternate sold by DuBro for Petrol and/or diesel fuel.
An old fashioned tin tank is much more useful.
This video explains the plumbing of the DuBro product.
#145
Well, we old timers make them out of tin, or Brass sheet (.008-.010" thick) with Copper or Brass tubing, and solder them together with Lead/Tin or Staybrite type solders and a low temperature iron.
As an alternative there are quite a range of containers made of Tin Plated Steel that can be converted.
Brodak is probably the only commercial source these days. However people seem to complain about how expensive they are.
https://brodak.com/fuel/fuel-tank/brodak-tanks.html
#146
If you're just running on the bench then you can make a decent tank out of a small glass jar with a screw on lid. DuBro sell a decent range of Brass or Copper tube. About 3mm or 1/8" diameter will do just fine.
Drill two interference fit holes in the lid. Cut and fit one tube so that almost touches the bottom of the glass. The exposed end of this tube will go to the engine NVA. The other hole is a breather. You can solder a short pipe into it, but it's not necessary.
You can also make diesel fuel tanks out of epoxy coated balsa. Some epoxies are diesel fuel proof especially those with a military specification. You do need to experiment if you're going that way.
